Butch50
Aug 01, 2018Explorer
Dennis12 wrote:
Try this first. When bringing your slide in or out, once it has reached that point of in or out continue to hold switch for a few seconds until you hear the motors kick out. This is how you keep both motors on your slide in sinc. Do this every time you use your slide. Like i said do this when going in and out.
This only works on schwintek slides and could cause problems on other slides. If the slideout is an electric with rack and pinon style that well only cause the slide gears to ratchet when the are fully out which is very bad for them to continue doing this. If hydraulic slide when the ram is at the end it is going to cause the pump to shut off and you can hold the button till the cows come home and it isn't going to move anymore.
The OP needs to let people know what type of slide mechanism he has for people to help.
ON EDIT: Roger10378 types faster than I do. :)
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
