bpounds
Apr 19, 2015Nomad
Rim width is the dimension between the bead seat faces. On most wheels you can just stick a tape measure through a hole in the wheel center, and eyeball it. Wheels run in even 1/2" increments, so you can figure it out. No need to take the wheel off the trailer. If you measure across the outside of the wheel, that will be about 1/2" larger than what you want to order.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
