wowens79's avatar
wowens79
Explorer III
Oct 23, 2023
How important is 90 degree turning?
We are looking at going to a 5th wheel from a TT. I keep hearing people talking about being able to turn 90 degrees. I really want to do with the standard B&W hitch in my F-350 with the 6'11" bed.
I realize if I turn too sharp I can damage the truck and camper, but I figure if I can turn a 5ver to 80degrees, that is alot sharper than the probably 45 degrees I can turn my TT. My current TT is 33', and the 5ver we are looking at is 35', so actual towing length will be shorter. Am I missing something?
  • MFL wrote:
    IMO, twisting to 90 degrees is just foolish, adds unnecessary stress to tires/wheels/suspension.
    As to the need...being a TT owner now, do you turn or back to 90 degrees? Of course you don't, you would hit truck/trailer.
    I have no issue turning/backing with my Ford standard bed, using a B&W non-sliding hitch. I'm more concerned about height clearance, with a FW, than hitting my cab.
    Nope, you're not missing anything, except that your overthinking the angle needed when towing a FW. Just like the TT, just a bit of pull forward to straighten, before continuing to back, is just common sense when backing any trailer.
    Jerry
    Thanks Jerry, that’s what I was thinking that I was only at probably 45 degrees with my TT, so even 75 would be plenty.
  • 14 years towing the 5er and never once came close to 90 degrees. Even in some tight campgrounds.
  • IMO, twisting to 90 degrees is just foolish, adds unnecessary stress to tires/wheels/suspension.
    Jerry
  • 4x4ord's avatar
    4x4ord
    Explorer III
    I towed my fiver for nearly 20 years with short box trucks and a nonsliding hitch. It’s not hard to do. I recently purchased a B&W sliding hitch and use the slider much more than I thought I would. It’s nice for hooking up …. especially at an angle. It allows ample room to walk behind the truck with the tailgate down. I can access my front basement compartment without unhooking. Now that I slide the hitch back for tight maneuvering I run the hitch a little closer to the cab while towing. I think it might tow a little nicer adjusted this way.
  • You don't need to get to 90 degrees, until you do. My experience has been that auto sliding hitches for short bed trucks are important.
