NC_Hauler
Jan 09, 2016Explorer
I towed a 5er that was loaded to 16,300# with a pin weight of 3460#..This from CAT scale weights and some simple Arithmetic. (Simple subtraction)
Don't really need any special "fill in the blank" calculator to figure if a truck can tow a certain 5er...Just some common sense in weighing one's truck, ready to "hook up and go, and compare to data plate on drivers door, i.e. GVWR, (most don't use this, but I still do), BUT, look at RAWR and again, just some very simple Math and one ought to be in the ball park to know if a particular truck can tow a particular 5th. wheel. take 22% of hers GVW and ball park pin weight you'll put in the bed of your truck, (on the hitch)..One should be able to figure out if the need a 3500 SRW truck or a Dually.
A 5er with GVW of 16,000# now? Went up 500#..I like the stability the dually offers, but would think OP should be able to tow 5er he spoke of with his 3500 SRW truck..
About Fifth Wheel Group
