Dealer must be slow to only be a week out
And make sure to pull the panel behind the water inlet and check everything good. They are known for waterleaks seeing they use waterhose behind the panel
That was when they used the Kantleak and guess what they did leak. In most cases it was a valve that leaked from what I was reading. They are now using the Nautilus P2 on most units and I haven't seen any problems on Grand Design owners group since.
TO THE OP Depending on the manufacturer date I would check to see if you have Lippert axles or Dexters. If Lippert than have the dealer pull the wheels and check the backing plates for grease. Lippert had quite a problem with the seals leaking grease and it getting on the brakes. Grand Design switched to Dexter axles and I have not seen any cases of this problem since then. We have the Dexter axles on ours.
