colliehauler wrote:
NC Hauler wrote:
korbe wrote:
NC Hauler wrote:
Bigmoss wrote:
Thanks guys the battery never crossed my mind at all and you guys are correct it will die. I guess I will just empty the fridge and disconnect the battery before I leave as I will leave the fridge door open and the light will stay on if I don't.
....remove light bulb:)....I'd still disconnect battery(ies), due to other voltage draws as alluded to earlier.
When my frig is turned off, the light will not come on while door is open, even when on shore power or with the battery on.
Same here...but I thought OP said he had "older" unit....on older units I could turn fridge off and light would still come on if door open.
Irrelevant if you disconnect the battery the light will be off.
agree...I was just for silliness stating that you could remove the light bulb and light won't work either...It's obvious there will be zero power to the unit if battery is disconnected..
