csamayfield55x
Sep 09, 2016Explorer
Someone else said it before but I will say it again, Measure your rig at a point unhooked. Then hook up and put that point at the same place then take a look at your pressure. That is where your pressure should be!! Everyone else's pressures don't mean squat (pun intended) to your setup. You need to get it right for your application.
Now, just for fun here is mine,,, With my old TT weighing at about 8500 loaded I put right at 30 PSI in the bags and if I had quads on a bit more. With my new 5er that weighs about 11K loaded I run 20 PSI. See what I mean about everyone's example will be different?? I changed my loading on my truck and needed less pressure
Chris
Chris
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
