- Curly2001Explorer IIGotta let the professional bolt guys compare and recommend replacements. These thread in a cast A arm that pins into the rails.
Curly - Cummins12V98Explorer III
mapguy wrote:
Technically you can't buy a Grade 8 bolt in a metric size. I suggest you look for Class 8.8 minimum but think you would be better served with a Class 10.9 bolt. You probably will have to go to a real hardware store or a bolt supplier.
Belmetric is a quality online
business that has a wide range of metric bolts
So what grade would you compare the CURT bolt to? - FlatBrokeExplorer IIMost bolts in an engine are torqued. The engine heats and cools thousands of times. How often do you re-torque those bolts?
- Curly2001Explorer IIWill go to the local nut and bolt shop where they specialize in hardware. Large industrial supplier here in town.
Curly2001 wrote:
Just checked the instructions again and it says check torque after the initial 500 miles and at 1,000 miles thereafter. Not too happy about every 1,000 miles. Will order a new set of bolts and go from there. The new trucks are a real pain due to the bed height. I have to tow a little nose high now to keep the bed rail clearance.
Curly
Order? As in from CURT or somewhere you can get a higher quality bolt like mentioned above. - Curly2001Explorer IIJust checked the instructions again and it says check torque after the initial 500 miles and at 1,000 miles thereafter. Not too happy about every 1,000 miles. Will order a new set of bolts and go from there. The new trucks are a real pain due to the bed height. I have to tow a little nose high now to keep the bed rail clearance.
Curly - Curly2001Explorer III will check to see if the directions say after the first 500 miles and let you know.
Curly - mapguyExplorerTechnically you can't buy a Grade 8 bolt in a metric size. I suggest you look for Class 8.8 minimum but think you would be better served with a Class 10.9 bolt. You probably will have to go to a real hardware store or a bolt supplier.
business that has a wide range of metric bolts - DuctapeExplorerI hope the instructions say “after the first 500 miles”. If it’s actually “every” 500 miles that’s a ridiculous requirement. A daily visual inspection makes sense, but I’m not getting a torque wrench out every day or 2.
- fj12ryderExplorer IIIJust a thought, use some anti-seize on those bolts if you think you'll be pulling them off occasionally. Just lower the torque settings by about 15%.
About Fifth Wheel Group
19,027 PostsLatest Activity: Nov 07, 2025
