dave17352 wrote:
B.O. Plenty wrote:
dave17352 wrote:
A couple pumps would be plenty with that few of miles. I know you don't want to over do it. JMHO
A couple pumps will do almost nothing. The grease goes in the backside between the seal and the rear bearing. To do a proper job you need to jack it up and rotate the wheel while pumping grease in my hand. It will take about 1/2 a tube to fill the cavity between the bearings and force some grease through and out of the front bearing. This is how they work. Once filled then a few pumps might do the job. I prefer to pack mine the old fashioned way.
B.O.
I assumed they had grease in them all ready. He has been using the trailer.
B.O. is likely correct, as many new trailers, including mine, have barely enough grease in the new bearings, to get them delivered to the dealer. It may take 50 pumps, to fill the EZ-lube system, yes, half a tube.
In any case, you need to add to the EZ-lube, until you see grease movement around the outer bearing, by the grease gun tip.
Once the hub cavity has been filled, you should see some grease movement after just several strokes of the gun.
Jerry
