Have 2001 cardinal No paperwork on specs. Would like to know how you get an accurate hight of trailer Is using just a tape measure accurate enough, or do some truck stops have something
I'm lucky enough to have a barn I can park in. I stop with the front AC under the door frame, and measure from the door frame to the AC, then from the frame to the ground and subtract. If you can find something you can stop under and do the measurements, that's the most accurate way to measure. Mine is 12' 10-1/4".
