RoyB
Jul 12, 2013Explorer II
good show...
I am curious now if you still have the ONE WAY value in the line after the fix. This one-way valve only allows the water to go from the city water connection to your water lines inside the trailer.
Without the one way valve installed when you have to use your fresh water tank using the on-board water pump it will squirt water out your city water line and drain your fresh water tank as well as getting a few things wet on the outside of the trailer....
Hopefully the part you got from the local RV guy fixes the whole thing...
Roy Ken
Roy Ken
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
