enblethen
Dec 14, 2014Nomad
I supported the door with a small hydraulic jack. Then used a small drift to knock the piano hinge pin up enough to get hold of the end with vise grips. I then hit the vise grips to pull the hinge pin up enough to install properly sized stainless steel washers at each point of the hinges. Then tapped hinge pin back down into place. Had to do this on all three hinges and two places in each hinge. I had tried using C clips but when the door rotated they came out.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
