NJRVer
Dec 14, 2014Explorer
If the top corner of the door is hitting the frame from sagging you need to shim the bottom of the hinge out and pull the top hinge in tighter. This will push the bottom of the door closer to frame and pull the top of the door away from the frame.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
