AZ_T_T
Jul 16, 2015Explorer
Dtank wrote:Arcamper wrote:
Our new Montana has a power fill only water tank and I try to check the gauge and stop at full but twice now I missed it and it started coming out of the vent. Montana says not to do this or damage can happen. I guess if you put water in faster than the vent can let it out you could over pressure the tank and burst it.
I slow it down now when its about 3/4 full.
Good plan........
Know the flow! - - especially using campground supply.
Some of 'em put out a LOT of volume!
*If* you must use an exterior *connection* to the RV, you may not know just what kind of quantity you are getting.....if you didn't check.
So check the campground hose bib - one turn gets you......
two turns, etc...;)
I also had 2 pex lines and both were over flow lines. I just tied them together with a T fitting and then out to the spigot.
Good luck!
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
