Oct 24, 2017Explorer II
N-Trouble wrote:I'm only lifting one wheel off the ground just high enough to remove it. It's compressing that one spring. If I keep jacking enough to raise the other wheel then yes, it will be 50%.2112 wrote:
I lift one wheel at a time at the perch with a 2 ton floor jack. It's only lifting 25% of total weight minus hitch weight. For my setup that's ~2080lbs per wheel on my double axle.
A triple axle would be 16.66% of total weight minus hitch weight.
Wouldn’t it be 50% of total - tongue? When you lift one wheel to raise the other off the ground your carrying the weight of both axles on that side.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
