DougE
Nov 05, 2014Explorer
I took a look at the wheel chock and it seems suitable for stationary use without bolting down. It would probably work in the rig to hold the bike steady until you can get them strapped down to anchors attached to the rig. Were I to use this in your situation, I would mount the two of them to a single section of 3/4" plywood and then set it in the trailer for extra stability. Depending on how closely you can space the bikes, a 2' x 6' section of plywood might do the job with the 6' dimension running across the width of the trailer.
About Fifth Wheel Group
