KimandChris's avatar
KimandChris
How to tell a quaility RV
Hi Folks,
DW and I are ready to move up to our second toyhauler. We fulltime so would like a quality unit. I have read through tons of threads here and know the consensus seems to be the best are DRV and New Horizons. Both of those are out of our price range as is the Excel.The Grand Design seems to be universally praised and is at the top of our list at the moment.
My issue is, how can you tell the quality of an RV? Detail I am most concerned with(frame/axles/wall construction, etc) does not seem to be available online. Most info seems to be about available options. I would much rather put my limited $$$ to a stripped down quality RV but am having a hard time determining which that is.
Even within manufacturers, it is difficult to determine what the actual differences are. The grand Design M-class is advertised as 'lighter'. As far as I can tell, that is the only difference. There seems to be a few options in the M-class that are standard in the TH class, so we are leaning towards the 348M.
What about KZ? We currently have an entry level Sportsman Sportster which has treated us very well for the last 6 years. I see very little about the Inferno and almost nothing about the Stoneridge(their full time rig). Are they all on the same frame? same axles? I need details! :)
Thanks for any insight.
Chris
  • Check out the RV Consumer Group, www.rv.org, to see what they have to state about the quality and reliability of the rigs you are interested in.
    I'm really not a fan of the `lite' versions. If they are really lighter in weight they have to reduce something to minimize the pounds. Maybe it's the frame thickness or the cabinet/countertop material, etc. it has to come from somewhere.
  • It's difficult. Rather than looking at the glitz, root around inside cabinets and cubbies, crawl inside the front storage compartments and look at plumbing and electrical wiring runs, and for sloppy and/or cheap components like bathroom faucets. Compare the frames and running components, including tires, from different mfgrs. to see if there are meaningful differences.
    I knew I was not buying a top of the line FW, but here's just one example I can share: after determining I had a very small leak somewhere in my plumbing (new FW), I removed the access panel for the washer/dryer hookup and discovered one of the four screws holding in the panel was screwed into the hot water line! That's sloppy workmanship IMHO. Not only that, I discovered the PEX lines throughout the FW have numerous unneeded joints and fittings. PEX is designed to be flexible (to a point) and I could have eliminated up to 20 unnecessary fittings (and possible places to leak) in just one 15' run of hot and cold water lines. It had to take the workman longer to put in all those joints than run straight lines, which doesn't make sense if these units supposedly are built so fast as to make them cheaper.
  • After owning 4 RV's all from different manufacturers, I have come to believe that yes, there are slight differences in quality. Generally, the more you pay the slightly better the quality...
    But, what you are really paying for are more options, add ons, and fluff.
    In reality....the handier you are with tools and fixing/tweaking the happier you will be with what ever unit you have..
    RV's (all of them) need constant attention.
