laknox
May 03, 2016Nomad
Also, if there's been a =lot= of grease passed through the axle seal, you'll likely see it slung all over the inside of the wheel(s) and the back of the hub(s). No matter what you get, if you're buying used, plan on a wheel bearing repack at minimum or a full replacement. FWIW, it should run you < $400 for good bearings, seals and installation. Some shops will run specials for a lot less.
Lyle
Lyle
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
