goducks10
Sep 26, 2014Explorer
Screw all that legal mumbo gumbo internet myth malarkey about being over weight. Anyone with the slightest bit of common sense can figure out that the only difference between a 3/4 ton and 1 ton is rear spring packs. 2013 and up Rams are the exception to the rule. A 3/4 ton with the proper rear suspension up grade and a good set of 18" wheels and tires will tow every bit as well as a stock 1 ton. In fact IMO an upgraded 3/4 ton is probably better than a stock 1 ton. Just looking at the payload numbers for my 12 Ram 2500 (2176lbs) and comparing them to a 3500 (2700) you only gain 430lbs of payload. I can get more of an increase with bags, springs or Timbrens.
Everyone has to determine their own risk factors. Is it a risk worth taking? For me it's not a risk. It's common sense.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
