rperrymExplorerSep 19, 2015Hydraulic PumpI have read about manually operating the hydraulic pump with a drill and a 1/4" hex bit. There is an opening on the end of the pump to insert the bit. Has anyone ever done this? If so, does it work...Show More
MNRonExplorerSep 19, 2015Depends on your pump, check your owners manual. Mine doesn't work with a drill but has a hand lever pump backup.
Related ContentWater PumpSuspect hydraulic pump (slides) fadingHurricane - Hydraulic Pump FailureLippert hydraulic pump problemHydraulic slide pump
