I have read about manually operating the hydraulic pump with a drill and a 1/4" hex bit. There is an opening on the end of the pump to insert the bit. Has anyone ever done this? If so, does it work...
My pump is the same way, two inches from a wall. I was thinking about moving the pump to a better position so I can get to the end of the motor with a drill.
