rperrymExplorerSep 19, 2015Hydraulic PumpI have read about manually operating the hydraulic pump with a drill and a 1/4" hex bit. There is an opening on the end of the pump to insert the bit. Has anyone ever done this? If so, does it work...Show More
rperrymExplorerSep 25, 2015Thanks everyone for all the helpful info. I do think I will locate the appropriate valves and make sure I can do it before I need it.Rick
Related ContentWater PumpSuspect hydraulic pump (slides) fadingHurricane - Hydraulic Pump FailureLippert hydraulic pump problemHydraulic slide pump
