SUMRX4 wrote:
Does cooler weather typically effect hydraulics operation. Winterized my unit last week and when I tried to close the main slides (hydraulic operated) they would move about 6" and stop and the touch screen would say "Fault occurred" I could release the control and touch it again and it would move about 6" and do the same thing. I'm thinking it was just because the fluid was cold and a little thicker.  Does this seem typical and if so, is there an additive to help with this issue?
You have an auto reset breaker that is getting warm and tripping. They reset themselves in 4-5 seconds. Your pump has to work harder in cold weather to move the fluid and is warming up your breaker sooner than normal. It's normal and won't cause any damage so don't worry. If you want to improve it you could swap out the breaker with a higher amperage one...easy to do.
