Unyalli wrote:
ricatic wrote:
Your comparison of the two gen sets, Honda Handy and the Champion Inverter is a bit disingenuous
Nope not one bit. The handy is Honda's lighter more portable 3000i and a direct apples to apples with the Champ 3100i.
ricatic wrote:
it is only 58db not 65db...
Wrong again sir. The Honda is 65db at full song such as when running an A/C as I clearly stated.
Noise Level 65 dB(A) @ rated load, 57 dB(A) @ 1/4 load
Click on the specs tab
Jeff
...not wrong...the Honda I referenced, which is significantly more popular than the Handi, is only 58db at full song...I did read the specs...49db to 58db according to the Wise Sales website...
I used the Honda 3000IS as an example because next to the paired 2000 Inverter Hondas, the 3000IS is a runaway leader in the marketplace...but I will agree that it is a bit heavier and that is why I bought 2 Honda 2000's and built an extended run setup for them...
But, I will say that on my next deployment this spring, I may take a long look at that Champion Inverter...but i will want to hear it run...it is light enough to throw around...and a quieter than that construction Champion...
Regards
