Got one that would have surely cost us thousands if it was taken to a dealer. Changing the black tank gate valve.
Our Alpenlite has a Waste Master electric gate valve system. Great when it works, push a button, not so much when it does not.
Changing the valve, in an extremely awkward inaccessible location, involves getting the tank empty as possible at the dump then going somewhere on a slope, or creating a list with boards to make what does not drain go to the low side away from the valve.
You then have to get under the trailer, with your face right below the valve that you have to remove.
I will stop the story there. It only gets worse.
