Padlin's avatar
Padlin
In the bed harness connection
I don't have my trailer as yet but want to install the connector/harness. I can put it at floor level right at the tailgate where it might bet beat up, just to the rear of the wheel well about mid level where I can still just reach it, above the wheel well where I can reach over the side to get to it, or up by the cab where I can also reach up over the side. Is any one spot better then the rest? I'm taking it the drivers side is fine.
  • I would not put it at floor lively, you could have issues with rain water
  • My Ford ready plug is at rear of bed, maybe 1/4th to 1/2 up from floor. At 5' 2" tall this is the best location for me. Too, many times I've had to get a ladder to reach over the side of bed and down to try and plug. When the plug is toward the front of the bed I just can't reach it with out really working.
  • Mile High wrote:
    ... I bought the type that is prewired with a T-tap that intercepts the bumper plug in the back so both work.
    mine is the same, but when plugged in, neither connector works!..
    if I slightly turn the harness side, and hold it with 2 hands, then both connectors will work..
    the stock connector by itself works every time.
    2012 Ford F350 DRW
  • The Ford factory install is higher on the fender, but it has a big surround plastic box that extends the depth (at least on the super duty).
    I ended up going high, right next to the tailgate above the taillight. Plenty of depth on the super duty anyway, and it was a snap to remove the taillight to route the wiring down to bumper. I bought the type that is prewired with a T-tap that intercepts the bumper plug in the back so both work.
    I had to go where I am because I have the factory bed extender racks that fold up in the space behind the fender well. The spot actually turned out to be ideal to reach when hooking up.
  • George H wrote:
    My last 3 trucks have been the same, midway between tailgate and wheel-well and 8 or 10 inches above bed floor. high enough to protect form dump/landscape loads and access from rear or over rail (assuming rail is not high).
    That is where my Ford factory installed connector is located.
  • My last 3 trucks have been the same, midway between tailgate and wheel-well and 8 or 10 inches above bed floor. high enough to protect form dump/landscape loads and access from rear or over rail (assuming rail is not high).
  • The spots I listed are where I have enough room, pretty limited.
  • make sure u know how much space into the fenderwell the bedside connector needs. I cut my first hole too high.
    I also have a dickens of a time getting the T connector to make good connections at the stock connector. I have two of the same harnesses (Hopkins 41157) and both show the same problem.
