valhalla360
Oct 20, 2014Navigator
Assuming the tail end of the tubes are inflated with nothing solid behind the transom, you could probably buy 12-18" by deflating. Just be careful of chaffing. If the tubes rub against the walls, they will eventually fail.
If you have one of the beds that raises and lowers, you could probably modify it hold the dingy and you raise it up to the roof to keep it largely out of the way.
The bigger issue is how will you launch and retrive it? RIB's are typically a lot heavier than a standard inflatable. Nothing crazy but 200-300lbs for a simple one (vs 60-100lbs for a standard inflatable) and it's bulky and akward. If the wife isn't strong and the kids are young, getting launched and stored will likely be the main issue. There are wheel kits that help but it may be more hassle than it's worth.
About Fifth Wheel Group
