KATOOM
Jul 30, 2013Explorer
I installed the 507 model. And regarding the temp readings, I called TST and asked them specifically about the accuracy of the temp reading and they stated that its a very accurate reading of the internal temperature. Within a couple degree's. That said, maybe the reason for the higher temperature the laser gun reads is because its picking up the tires surface temperature, which would make sense since its black and the direct sun on the tire would cause a laser temperature gun to read a higher temp than a tire sitting in the shade.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
