Cummins12V98
Nov 03, 2016Explorer III
ScottG wrote:
I vote for doing it myself. If a dealer screws it up they will patch it in some hideous way. Dont count on them paying for some elaborate body work to fix it - most wont. In fact it wouldn't sruprise me at all if they drill through a stud and just left it that way.
If I did it I would drill a small hole on the inside of the wall, stick a bent coat hanger in there to make sure there was clearance and then drill the big hole. I would also try a stud finder but they dont always work with RV's.
Only drill the big hole through the inside paneling so you can check closer for issues. If nothing is in the way, just pierce the outside with the pilot screw of the hole saw and then go outside and drill inward for a clean hole.
AGREE!!!
About Fifth Wheel Group
