Dr_Bobs_Patient's avatar
Nov 03, 2016
Installing Dryer Vent '16 Keystone Cougar 333MKS ???
I'm installing a Splendid 2100XC vented washer dryer combo in my 2016 Keystone Cougar 333MKS. When I got into the w/d cabinet I found these instructions for installing a dryer vent:
FIRST - In the washer/dryer cabinet
Drill a hole in rear wall inline with dryer outlet.
SECOND - Remove panel in front storage pass thru.
THIRD - Locate vent in sidewall in step area on door side of unit & run hose between outlet & vent.
These instructions make no sense to me.
1) Is the rear wall reference the rear wall of the cabinet? If so, that would be front of the FW. And by what I can find, there's not enough clearance in that wall for a 4" pipe.
2) My front storage is not a pass thru and the pass thru storage removable panel is located on the opposite side away from the bedroom. I do not see a pathway for a vent through the pass thru storage.
3) The step area door side is 15 feet away from where the w/d cabinet is. That seems an awful long way to go for a dryer vent.
Can anyone shed any light on these instructions or should I just locate the vent in the side wall of the FW which I have read about in all of my searches concerning installing dryer vents?
Any information, pictures or help would be greatly appreciated. Thanks in advance as many of my other questions have been answered through the search feature here.
Bruce
__________________
  • not to be a pain but this would almost be a stealer-ship deal that way they screw it up they can fix. You screw it up you are on the lamb.
    I can access my campers under storage cabinet panel (I was just in there on this last trip. almost half the screws had fallen out) so I pulled this panel and straightened some wiring out behind it and wire tied some more then put some new screws in and vacuumed the carpert. but there is nothing to access in the front storage box. You would be straight down from the front closet I think on my 327RES anyway.
    randy
