netjam
Oct 07, 2013Explorer
Heated and insulated tanks mean only when your furnace is operating. There is no other source of heat to that area. The insulation KZ usually uses is one sheet of tin foil so its not much but you don't need much if your furnace is running. The previous responses are good. Without the furnace running (while traveling) you be advised to winterize if its below 20. If you are running the furnace at nights while travelling, you would likely be OK if its above 20 during your journey.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
