Jerrybo66
Aug 09, 2014Explorer
fishingbob61 wrote:
You might have to shim out the striker plate.
If that's the problem, it would be less noticeable to shim the hinge.
Loosen the hinge screws, insert shims, possibly from a Kleenex box, 3/8 X the length of the hinge and put it under the pin side. Retighten the screws. That should move the door closer to the strike plate.. If that's not your problem, you're on your own.. :) :)
About Fifth Wheel Group
19,015 PostsLatest Activity: Jun 02, 2025
