skipnchar
Aug 09, 2014Explorer
Loose hinge screws will also cause the door to fail to latch properly. Another reason is SOMETIMES the way the RV is stabelized. Too much weight on the stab jacks can put a slight bend in the frame which can also cause latching problems (but only when stabs are used). If you don't find any loose screws then aligning the latch plate with the door latch will probably fix it.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 23, 2025
