kserkes's avatar
kserkes
Interior width
Are any of the wide body travel trailer haulers wide enough to put 2 ATV's in side by side??
  • Yes it's pretty common that you can fit in two Utility ATVs in the 102" wide haulers. The door is your limiting point, but even with that it's pretty easy. The other area to watch out is if you have rear beds as the rails can stick out. In all cases measure your ATV and the space between, you should fit.
    In my case I pulled one in a bit further then the second in place and move the first one back a bit. If you're worried about scuffing up the sides, use an old carpet scrap or cardboard.
  • Yes, I can put two utility quad's in my Keystone Fuzion 393 side-by-side, but the tires rub each other and the wall a bit.
