azbohunter's avatar
azbohunter
intermittent brakes
I am having the intermittent brake problem. I have done some diagnostics as recommended in other posts. I pulled the emergency connection and all four wheel rolled, I checked for power at wires coming out of that connector and had power, crawled under trailer on drivers side and checked for power at front axle, good. Checked rear axle and it was no go, wiggled some wires, pulled on wire going through axle etc, checked power and at rear axle drivers side again and it was there. Went back to truck, plugged emergency connector back in, checked dash brake with manual slide controller and it went up to 10, pulled the emergencey plug and all four wheel slide? So I have determined that the problem is wiring and not magnets or in the hub..but don't know where to go from here?
