azbohunter's avatar
azbohunter
intermittent brakes
I am having the intermittent brake problem. I have done some diagnostics as recommended in other posts. I pulled the emergency connection and all four wheel rolled, I checked for power at wires coming out of that connector and had power, crawled under trailer on drivers side and checked for power at front axle, good. Checked rear axle and it was no go, wiggled some wires, pulled on wire going through axle etc, checked power and at rear axle drivers side again and it was there. Went back to truck, plugged emergency connector back in, checked dash brake with manual slide controller and it went up to 10, pulled the emergencey plug and all four wheel slide? So I have determined that the problem is wiring and not magnets or in the hub..but don't know where to go from here?
  • Mike134 wrote:
    Replace all the splices, wiring never fails in the middle, always at the connections.
    I have checked everything visible and I can't see anything that looks like it would be a problem. I have heard of insulation wearing off inside the axles over time. It might not be my problem but I think that I will pull new wires thru and then I will know.
  • Replace all the splices, wiring never fails in the middle, always at the connections.
  • Thanks to you both, sound advise. I will try the light bulb thing and see where that goes but seeing how my rig is pushing 20 years, I might just start at main wires and run new through axles and hopefully be covered.
  • Disconnect from TV, and wire between battery (+) and breakaway switch. Using jumper wire, put a light in that wire, so it grounds thru brakes. Watch light while you shake wires. When it flickers/or goes out the bad connection is in your hand
  • The easiest way is to run new wire from the known good point to all the brakes. Just make sure you use large enough wire.
