time2roll wrote:
laknox wrote:
AFAIK, Yamaha is the only genny with a "burst" capability, where it pulls power from the starting battery for about 10 seconds, to help start the A/C. Would love to see that on a Champion!
Lyle
Independent inverter to be used with or without the generator.
https://www.victronenergy.com/inverters-chargers/multiplus
Unique PowerAssist feature
The MultiPlus will prevent overload of a limited AC source, such as a generator or shore power connection. First, battery charging will automatically be reduced when otherwise an overload would occur. The second level will boost the output of a generator or shore side supply with power taken from the battery.
That's pretty cool! Never seen that one before; thanks for the info. FWIW, my cousin that's building the bus into an RV, is using Victron equipment and loves it.
www.beginningfromthismorning.com.
Lyle
