I have a 2013 voltage 3905 I would like to add a 5k inverter. I have 4 - 6volts 215 amphours each. They are set up in series/parallel. Has any one added an inverter and did you add a second transfer s...
By 5k you mean 5000 watts, peak or continuous? Get four more batteries and run 'em at 48volts. 5000 watts at 12 volts is 416 amps, you're looking at doubled or triple #0000 cables, and short ones at that. 5kw at 48v is about 100 amps or enough for a single #0000 cable to handle, even at length.
