QFP
May 30, 2015Explorer
Inverter question
I have a 2013 voltage 3905 I would like to add a 5k inverter. I have 4 - 6volts 215 amphours each. They are set up in series/parallel. Has any one added an inverter and did you add a second transfer s...
pianotuna wrote:
Hi,
I simply plug the shore power cord into the inverter. I set the fridge to propane, and disconnect the converter.
If you want the battery bank to have a long life, then it is best to stay above 50% state of charge--so the usable amp-hours are about 200.
I know of no reliable 5000 watt pure sine wave inverter. Stay away from the Chinese ones.
