I have a 2013 voltage 3905 I would like to add a 5k inverter. I have 4 - 6volts 215 amphours each. They are set up in series/parallel. Has any one added an inverter and did you add a second transfer s...
Try using a French press and heat your water on the stove for coffee. Forget about the TV, and you can go for 2 or 3 days without listening to the generator. Enjoy the silence in the boonies.
