- newman_fulltimeExplorer IIbe me I would get a short because b& w patriot and a Reese sidewinder air pinbox
- JIMNLINExplorer III
Retired Sailor wrote:
Looks like we're going to switch to a 5th wheel so I need to buy a truck. Do I need a long (8') bed or will a short (6'4") bed be sufficient. Im not worried about other cargo and the short bed would be easier for the wife to drive around town. Thanks
If you notice those with a short bed GM trucks say they may have a slider but its not ever used or have one. Thats because the GM short bed truck has a longer dimension from the back of the cab to the trucks rear axle. So .....when the hitch is installed in the bed with the pin zero over the rear axle you get the full benefit of that longer length.
My son tows a 34' bunk house with three slides with a '02 short bed chevy and now a 2015 2500 chevy short bed 4x4 crew cab with no slider nor is one needed
Now my short bed quad cab Dodge/Cummins needs a slider with my old '97 trailer with a very flat square corner profile. It's never used going forward but when the pin is slid aft 13" behind the trucks rear axle it requires much less steering input when backing around corners. I like that feature. He can back a full 90 if needed on any terrain. - Golden_HVACExplorerHi,
Like many have stated, the longbed will ride smoother, have more space, so that the trailer is not trying to come in the back window, and have room for cargo too. It might also have a larger fuel tank.
What to be very careful about (I hear this question a dozen times a month) is do not buy a 2500 pickup for towing a fifth wheel. "The dealer said it would tow anything" is something that I hear time and again! Sure it is 'rated' to tow a 15,000 pound fifth wheel, but the cargo rating might be 1985 pounds, or enough for 20% of the hitch weight on a 7,500 pound fifth wheel.
The hitch weight will be around 150 pounds. You know what the passenger weights will be. IT all adds up quickly, and if you are looking at moderate light 12,000 pound fifth wheel with a 20% hitch weight, that is 2,400 pounds!
So look at the fifth wheels first, and then decide on a pickup. If you fall in love with a Montana fifth wheel, and it happens to be 31' long, with a 14,000 GVWR and 2,000 'dry pin weight' you do not want to already own a pickup with a 2,500 pound cargo rating. You will need to install a 150 pound hitch, and carry 2-3 people, so figure about 500 pounds in the cab, 150 hitch, 2,000 pin weight, that is 2,650 pounds! Add to this any options you might select with the pickup, like 4 wheel drive (about 500 additional pounds that the dealership did not tell you about) crewcab models are around 400 - 500 pounds more than a regular cab.
Get a towing guide for whatever pickups you are looking at. On the Ford towing guide, you can look at 'slide in camper max weight ratings' and get an idea of what a SRW F-350 can carry, VS a F-250 or dually F-350 pickup. Max camper weight is pretty close to your max cargo rating.
In 2005, Ford really stepped up to the plate with some heavy duty pickups. While a 2004 F-250 supercab would have a 7,000 pound base weight with 4X4 and diesel engine, it only had a 8,800 GVWR, crewcab was even heavier curb weight, so less cargo capacity. In 2005 and later models, most F-250's have a 10,000 GVWR, while the SRW F-350 was 11,500 or so, and DRW F-350 could carry as much as 5,500 pounds!
GMC and Dodge caught up a few years later. I can recall a friend with a dually work truck, it was a 1985 Dodge with 10,500 GVWR, and it would wallow around corners, as my buddy put it.
God luck, and happy fifth wheel shopping!
Fred. - broark01Explorer IIHad 2 SRW short beds and like many above, hardly ever used the slider. They were fine for most 8-10 hour tows. Now have evolved to a long bed DRW to head out west and cover thousands of miles. It definitely handles better with the 5th than the short beds did but the short beds did fine.
- john_betExplorer III am a long bed type. My choice for my reasons. Mine has a 160.5" wheel base and is my DD to where I need to go. Cab length and bed size dictates wheel base and over all length thus ability to get around town in. JMHO.
- Cummins12V98Explorer IIIGet a truck, that means a standard, long bed. No gimmicks needed with the hitch.
Better ride the longer the wheelbase. Can haul things much easier. Yes short bed people I have owned a short bed before, I hated the bed, loved the truck!
Get the longed with the factory puck system and a hitch like this and you will even have room for a toolbox like this.
- LOFAT36ExplorerI have a short bed and a slider. I've only used the slide a couple times as I prefer pull through sites. However I never thought about it backing up once until I heard the crunch. Dented the cab & broke my power slide rear window. To me the short bed is plenty long enough.
- hbillsmithExplorerShort bed is 6.4' on the Ram, 6.5' on the Ford and 6.6' on the GMC Chevy. Axle placement relative to cab distance varies also. I am no slider, see my signature below. All this aside, I concur with pick the fiver first.
- donn0128Explorer IIBuy what you like. It is your money afterall. Personally I like the long bed for hauling stuff, not just the fiver.
- Old-BiscuitExplorer IIIWell...........
Looks like others have covered the slider for use with 6.5 (Yes/Maybe/No)
Now lets move onto SRW vs DRW :B
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 27, 2025
