SDcampowneroper
Jul 07, 2020Explorer
We use one, with our electric jacks it helps a lot. . what we do is lower the front several inches below level front to rear, run the rear scissor electric jacks down tight until the motor cuts out , then lift the front with the jacklegs to level which places more weight on the rear scissors then set the tripod under the pin and lower until it has good weight on it. Maybe not as stable as JT strongarms, but a lot easier and cheap. Set the tripod with one leg straight forward the others to the rear sides.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
