memtb
Jul 09, 2020Explorer
I think that several factors may lead to an answer. How sensitive are you to some RV movement? Are you using conventional “stabilizers” or have hydraulic leveling....which “should” offer a little more stability. How heavy is the RV, and how “stiff” is the frame of your RV? We have a heavy RV ,20K pounds when loaded) with a rigid frame.....you could Square Dance inside, with little shake or movement! A lighter, less rigid framed RV, would likely exhibit much more movement!
It’s strictly a personal preference thing! For us, in 30 years of 5th wheel use.....we’ve never seen it as an issue! memtb
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
