goducks10
Mar 18, 2014Explorer
DSteiner51 wrote:NC Hauler wrote:fj12ryder wrote:spud1957 wrote:I believe this was posted while the writer had his tongue firmly planted in his cheek. :)
Couple things you need to understand from this forum:
1. 1/2 ton trucks are only good to pull pop ups
2. Never exceed your GVWR unless you have a 3/4 ton
Probably right...least I hope so:)
Not sure why as this is exactly the message of many on RV.net. Many 3/4ton trucks have no more payload then a 1/2 ton because of all the options piled on but it is ok to add helper springs, timbrens, or airbags, then chip the engines to overstress the power train to boot. If one does that to a 1/2 ton then it is a crime subject to the death penalty, as it explodes and kills everyone in the area.
The difference between a 1/2 ton and 3/4 ton is the 1/2 ton will be at it's RAWR when it hits its GVW. When a 3/4 ton hits it's GVW it still has over 1000lbs left on its RAWR.
About Fifth Wheel Group
