rhagfo
Mar 19, 2014Explorer III
jaycocreek wrote:
Everyone has there opinion and has to choose to believe the vehicle manufacturer/the RV manufacturer or us guys on the internet. Lots of choices but the choice of most is go heavy tow vehicle and I don't disagree. Until now my tow vehicles have always been atleast 3/4 ton but my F-150 is rated exactly the same as my older F-250.
To be on topic,here is what Jayco offers in 1/2 ton towable fifth wheels and there recommendationsOverviewFloorplans and SpecsStandards and OptionsConstruction DetailBuild and PriceDownload a BrochureOwner's ManualWarrantyCompare Models
1 / 14
27.5BHS Interior with Pewter Décor
2014 FIFTH WHEELS
EAGLE HT
Weighing in under 8,000 pounds, you — and your truck — will fall in love with the easily towable 2014 Eagle HT. This Jayco lightweight fifth wheel loads up on comfort in an easy-to-tow design.
Here are a few of the nearly 100 half-ton trucks that can tow many of our Eagle HT models:
1. Chevrolet Silverado 1500, 6.2L V-8 Engine, Extended Cab, Standard Bed, Axle Ratio/Equipment - 3.73:1/Towing Package
2. Dodge Ram 1500, 4.7L V-8 Engine, Regular Cab, Short Bed, Axle Ratio/Equipment - 3.73:1/5-speed AT
3. Ford F-150 2WD, 5.0L V-8 Engine, Extended Cab, Standard Bed, Axle Ratio/Equipment - 3.73:1
4. GMC Sierra 1500, 6.2L V-8 Engine, King Cab, Short Bed, Axle Ratio/Equipment - 3.73:1/Towing Package
5. Nissan Titan 2WD, 5.6L V-8 Engine, King Cab, Short Bed, Premium Utility Package
6. Toyota Tundra 2WD, 5.7L V-8 Engine, Regular Cab, Long Bed, Towing Package
* Consult with your authorized automobile manufacturer or vehicle owner’s manual.
Well the manufacture may need to review their choice.
Technical Specifications:
Length (ft) 31
Length (ft) 10
Dry Weight (lbs) 7205
Payload Capacity (lbs) 2745
GVWR (lbs) 9950
Hitch Weight (DRY) (lbs) 1310
Yep!! They could all carry it DRY, with only a slim driver!, I doubt if 75% of them could carry it within GVWR, let alone rear GAWR, if loaded for even a "lite" camping trip.
That 100 truck is different models of the same five makes.
About Fifth Wheel Group
