LarryDel's avatar
LarryDel
Explorer II
Mar 18, 2014
Is half-ton truck big enough for a lite weight fifth wheel?
Hello:
We are about to make a purchase for a fifth wheel that we can pull with our pick up.
Here are the stats on our pickup:
2012 Chevy Silverado 1500 with max trailering package which includes vortec 6.2L-V8 SFI engine, 6 speed auto trans., heavy duty trailering axle. Towing capacity 10,000 lbs and payload capacity 1787 lbs.
We are looking at two Cougar X-Lite fifth wheels:
1. Cougar 28SGS
7561 Dry Weight
2439 Carrying Capacity
1410 Hitch weight
2. Cougar 29 RET
7825 Dry Weight
2175 Carrying Capacity
1275 Hitch Weight
Is our tow vehicle adequate for these two units.
Look forward to your comments and suggestions.
Larry
  • #1 is likely going to have a real-world hitch weight of 1,867 pounds
    Estimated pin weight for Cougar 28SGS
    #2 is likely going to have a real-world hitch weight of 1,800 pounds
    Estimated pin weight for Cougar 29RET
    With your truck's payload capacity 1787 lbs., that doesn't include anything in the truck other than full fluids. You have to deduct the weight of the driver, all passenger(s), the fifth wheel hitch, anything in/on the truck (rolltop cover, nerf bars, firewood, cooler, EZ up, etc.) or any travel comforts in the cab (GPS, laptop, activities, food/snacks, drinks, etc.). Use this calculator for estimating the amount of actual payload that you have.
    People do it, but it's not for me. I wouldn't want to be in a situation where I'm exceeding my payload with pin alone.
  • Not thinking that either one of these will work. Problem is your 1780 truck payload.
    With hitch installed and with a trip loaded trailer you will most likely be over that payload rating.
    Sorry. I know this is not what you wanted to hear. Hopefully others will give you a more positive answer.
