Me Again wrote:
You have a 6500 RGAWR. What you need to know is how much the rear axle weighs ready to tow. Understand you will be over your trucks GVWR, and that you may need air bags to level the truck when put the pin weight on it. It should handle 2500+ pin weight under those conditions.
Ram made a larger separation between the 2500 and the 3500 single rear wheel when they went with rear coils on the 2500 for a softer ride.
Chris
Agree with Chris, a 2500 lb pin would likely work. That would be about a 12,000 lb. scaled weight, ready to camp FW.
Jerry
