MFL wrote:
I think many are being mislead by the parking lot pic! That FW loaded, will have well under 2K pin weight. That truck, 250 with 350 suspension is not going to sag, or require suspension help. I have the same truck, with more pin wt, and very little squat. These 250s still have a 2" block vs a 4" block for the 350, so they sit mostly level when empty. While mine squats about an inch loaded, it could easily take more pin wt, without any further suspension enhancement.
Jerry
Nothing misleading in the pic. Pretty easy to see front fender height is higher than rear.
But thats the problem with F250s. They sit level when unloaded so any load puts them nose high. GM and Ram get it right and put some rake in the truck when empty.
