danrclem's avatar
danrclem
Is This Level Enough?
I'm new to 5th wheels and took this on a trip and even though it rode well it was too high in the front. I lowered the hitch 1 notch which looked to be 1" and it's still not level. The bottom in the front is about 2 1/2" higher than the bottom in the back. Would any of you lower it more or should I see how it tows before making another adjustment? It has plenty of distance above the bed. The next adjustment would probably be on the pin box.
Thanks, Danny
  • Maintain 6" bed clearance for sure. The more you lower the RV's front the more weight is applied to the trucks rear suspension. Could be the pic but the truck looks to be a bit low in the rear.
    Thanks, Danny
    Frankly, I simply don't think that's enough to worry about. Do you have any adjustment in the suspension? I'd much rather raise the trailer a hole, if you have it, to maintain bed clearance.
    Lyle
  • IF ----big IF----you can maintain at least 6" bed rail clearance then lower hitch or raise pin box one more hole.
    IF doing so would cause smaller bed rail clearance then leave it as it and go camping
