- HalmfamilyExplorer
Hamops wrote:
I had JT Strongarms on our previous 5vr and they worked well. I found that if we were situated in a spot for more than two or three days, I had to tighten them up.
I decided to now install them on our new 5vr because the old back took a beating everytime I had to tightened the T-Handles on the Strongarms.
That's why you go with Steadtfast fast system. Only three handles to tighten. - HamopsExplorerI had JT Strongarms on our previous 5vr and they worked well. I found that if we were situated in a spot for more than two or three days, I had to tighten them up.
I decided to now install them on our new 5vr because the old back took a beating everytime I had to tightened the T-Handles on the Strongarms. - TimayExplorerI was always bad at math! And the JTs are on sale now so you get all 6 for $220!
Tim - fj12ryderExplorer IIIActually it looks like you need three sets of them at $79.95/set. That makes $240. They come with two arms/set, and you need six arms if you're comparing to the JT Strongarms since they also do the back stabilizers too.
- TimayExplorerBAL lock arm stabilizers (nearly the same as JT Strongarms - different lock nut is all) but the price is much better at $160 bux. You need two sets of two at $79.95/set.
Click the link
Tim - N-TroubleExplorer
JohnG3 wrote:
We have the Winfield stabilizers. Easier to install and set up.
Not in the same category. looks like it only does 1/2 the job of the JTs or Steadyfast. Only has two front cross members from what I can tell. No for/aft stabilizer or stabilizers in the rear. - JohnG3Explorer IIWe have the Winfield stabilizers. Easier to install and set up.
- N-TroubleExplorer$275 for Steadyfast and worth every penny. Best investment on the trailer so far. My time is worth more than it would take to make them...
- James57ExplorerThey are great but expensive. So I looked at them really good and built my own. It cost me 50 dollars to build my own and they work great.
- Buckeye_ChuckExplorer II.
About Fifth Wheel Group
